Hello, I have a RC Components Accelerator tuner for sale. It is less than 6 months old. It came off a 2013 Street Glide.
250.00 Shipped.
This is what RC Components description says.
No Dyno Tuning, No Programming, No Downloads. The RCX-Celerator is the best of the best in fuel management! It is a full closed loop system which means it does all the work for you. Just plug it in and ride, it is that easy! This new design for the 2008-2013 HD Touring models features a 2 plug harness that makes installation fast and easy. The RCX-Celerator works with the factory ECM, Crank Position, Throttle Position, and O2 sensors to automatically detect and adjust for changes in load, temperature, elevation and throttle position so that your bike will always be running at its best no matter where you travel. The RCX-Celerator Fuel Management System also automatically adjusts for engine modifications such as adding a new exhaust system or air intake. With the RCX-Celerator installed on your bike you have an an on-board computer that analyzes your bike’s performance and constantly tunes the air/fuel ratio for optimum performance.
What Motor?
For the 103", correct?
