i have a 2006 Road glide and the rear brake light stopped illuminating when rear brake applied. Front works fine. Help please!!!!!!!!!! thanks
Uhhhhhhhhh.........did you try replacing the multi-element bulb in the tail light???:rolleyes:
Got it. Didn't see any indication in original post. Don't have any experience with a brightass light so have to pass, though I'd guess it's a controller issue that's on the fritz if all your LEDs aren't responding. Good luck!
Rear brake switch?
wouldn't have mattered even if it wasn't a bal. if the brake light illuminates with the front brake, then the bulb is fine. i'm thinking rear brake switch. you're gonna have to break out (no pun intended) the voltmeter and start checking everything from the switch back.
