19 RG bought last yr 3 k on it. Now 15 k. Blew rear head gasket replace last wk end. Ran from me for a wk. now rear cylinder shut down. Limp mode ??? Help
Any codes?
Any codes
When I first finished rear head gasket. There was an eco code. I cleared it at speedo. Figured was because of all the plugs that came undone
Any codes? No codes
ECM and BCM RAD was on there also.Any codes?
Other things that were done to it. Was true duals VH and naked air cleaner with power vision 3. Did them a month ago.Any codes?
So this might sound stupid but I watched a video where a guy showed the small area between the cylinders, mainly the rear, and it was a video about the crankcase pressure and doing the dipstick vent mod? Could it have anything to do with crankcase pressure? If that sound stupid nevermind...lol.If the bike is going into limp mode then there will be DTC codes.
Why did the bike blow a head gasket ? Did you replace the head gasket or have a shop do the work?
Did you do a compression test to see if the rear cylinder has compression?
If the rear cylinder lost compression you have another failed head gasket unless you have a loose sparkplug. If the head gasket failed then whoever did the work replacing the head gasket either didn't torque the head bolts to specs OR the head bolts were over tighten and the cylinder studs pulled out of the crankcase which is a expensive fix.
Mark
I'll have to keep looking. I'm probably wrong but whatever it was, I remember he showed the head gasket and explained why it failed in the rear portion between the two cylinder holes. Just can't quite remember why, driving me crazy......I'll keep looking!As far as I know your crankcase butterfly vent valves have to fail closed to have crankcase pressure build and all that would do is cause the the crankcase to sump causing the bike to run bad .
Never heard of that being a cause of head gaskets blowing.
Mark
