1 - 2 of 2 Posts
Good evening. So I have the Cerwin Vega b54 amp with the BT Line Leveler for the front two Infinity Kappa speakers. I want to add speakers to the new lids in the back. I assume i need another line leveler. Do i also need a breakout connector. Not sure other than speaker wire, speakers, and obviously connectors what more I need? Infinity Kappas are 2 ohm. Should i stay with a 2 ohm rears or does it matter? Any advice would be great. Ty.
You only need another line leveler if you want to be able to fade front to rear. If you want that then you need to get the radio flashed also to the Ultra (4 speakers no amp) flash. If you don’t care about fade then the one LL with an RCA splitter from the LL to both input channels of the amp will work. The brake out harness is for the Ultras. You will have no problems running 2 ohm speakers on one set of channels and 4 ohm on the other.
1 - 2 of 2 Posts
