1 - 16 of 16 Posts
It does do something. It has a spring. It helps hold the sprung weight of the bike. It just doesn't help with adding more preload.
From what I’ve read, due to the rigidity of the rear swing arm they only need to make one adjustable. The same principle of a mono shock. Adjusting the one effectively increases the spring preloaded but like most would think there is an unbalanced effect but has no issue do to the design of the suspension as a whole.
Maybe if they put preload on BOTH sides the rear suspension would not Suck as much as it does?
Ooops, did that sound bitter? :grin:
no you correct on the SUCK, just do like I and many others on here did, take off the OEM rear JUNK and Throw in the garbage, order Aftermarket and never have your Spine compressed again
TY I did, my super shox are going on their 3rd RG shortly!
X2!
my L5 is still thanking me for the upgrade :grin:
Though only one side is adjusted for pre-load, the other side still takes on weight for balance. It seems to me that one side would still be under greater stress, but I'm not an engineer. In my opinion, if you are running low weight and not pushing the limits of the bike you can get by with them. I personally have purchased a superior suspension, but I probably could have gotten by if I wanted to wait longer.
[/quote]
TY I did, my super shox are going on their 3rd RG shortly![/QUOTE]
I'm thinking about ordering some super shox next month. Did you go with the 14 inch and lowering blocks?
I upgraded to Ohlins (best choice I ever made), instructions clearly say to set the preload on both...seems intuitive to me that you need equal response from both shocks...
I'm thinking about ordering some super shox next month. Did you go with the 14 inch and lowering blocks?[/QUOTE]
Sorry just catching up, 13".
Man oh Man!!!!! We need to get a group buy together for some of these more commonly ordered items around here. Maybe @Smarty, can put together something for Ohlins or Brian would be willing to do something for the Super Shox crowd.....
Sorry just catching up, 13".[/QUOTE]
I went with 13” and then a month or so later decided to go with the 14” with the blocks. I have an ultra so a little more bang on big bumps, mostly crappy transitions from road to bridges.
The 13” were good but with the 14” I can have a much more plush ride and not bottom out. The blocks he provides are good looking like his shocks.
Brian is great to work with.
Stock Shocks
On the stock shocks, the left side is adjustable for compression and the right side set is for rebound.
1 - 16 of 16 Posts
