1 - 20 of 21 Posts
I did my first 3 hole oil change on my (new to me) 2015RGS in the Fall after watching Ryan Urlacher's YouTube video with no issues. I just took the bike for a nice long ride and came back to drain the hot fluids and removed 4 bolts, not 3. The picture attached shows the 4th plug I wasn't supposed to remove (#3 labeled Hex Plug (do not remove) from the Service Manual...uggh... I realized something wasn't right when it had red thread lock on it after I took it out. Question - How bad did I screw up and will the fluid that came out of that hole be replaced when I fill the 3 holes? I'm hoping someone here knows what that plug drains...Thanks in advance for your help and advice!
Don't over tighten it or it could cause a problem. Do as others said and then leave it alone.
yep, it's a tapered pipe plug. overtighten it and you'll have worse problems.
i believe in the manual they refer to them as crankcase pipe plugs and have a torque spec of 120 INCH/lbs.
Skratch - Thanks for the torque specs and name of the plug! I just verified in the Service Manual and you are correct Sir! Wasn't even sure what to look up before you replied...Thanks!
Now if I can just find a way to sew the mattress tag back on I'll be in good shape :)
Thanks again for the replies! Now I can finish the rest of my maintenance, replace brakes and flush the brake fluid so I can get my rear tire replaced before Gettysburg!!
OMG ,,, that's worse than removing your mattress tag.
Yes this is a tapered plug! Hamfist this one and the case will crack! 120 inch pounds equals a 10 pound pull with 1 foot worth of leverage! Put sealant on it and go real ez. I did the same thing my first oil change, no worries!
Do not remove
If you have an oil scavenger setup, you use that hole to drain the last dregs of oil from your engine.
1 - 20 of 21 Posts
