1 - 1 of 1 Posts
2020 Limited.
Been looking for a half helmet with flip down visor more for rain than sun. Went with the CarbonFiber for weight. I usually wear a L without do rag xl with. This helmet fits very small I got the xlxxl and figured I could adjust down with the fancy one size fits 2 adjuster. Wound up taking out the adjuster and helmet fits fine. Wears comfortable at least up to 80+. Shield has some distortion but not bad enough not tho use it. Helmet is crazy light.
My advice be very careful on size if you are not trying one on. RevZilla indicated I could return as long as I only tried it on re packed and returned. Was no need since I figured out how to make it work. If you wear an xxl normally this isn't going to,fit.
Safe journeys y'all
1 - 1 of 1 Posts
