1 - 20 of 30 Posts
If you run the four channel up front for the four front speakers. How would you hook up the two channel amp to the same system to power the speaker lids?
I'd recommend one 2 channel amp per set of RCA's or fade positions
FRONT and REAR
so, 2 amps, one up front and one for the rear
Then make the speakers used match in impedance, to the benefit of
amps total output power.
Be is 2, 4, or 8 speakers per channel, the amp doesn't know the difference, the
amp just reads the ohm resistance and reacts accordingly
on the PBR300x2, the 2ohm mode draws the most usable current so a 2ohm load is the most efficient,
be it 2 pairs of 4ohm speakers (best) or a single set of 2ohms, or 4 pairs of 2ohms,
but that's all one channel so placement should be similar
Ok you lost me sort of. I already have the 4 channel amp set up in the front. I need more power too power up 6x9's in the lids? How does one tie those two amps together? Should I run the front fade to 4 channel amp for the front speakers and the rear fade to the 2 channel amp to power the speaker lids? ?
exactly, two separate channels
the biggest road glide challenge was SPACE
anything over 1.5 thick has a tough time fitting, eliminated a bunch of amps
up to about 1.8" in between the glove box space, only so much on top of the
radio, etc....
so the PBR was a little no brainer for that reason, maybe the crossovers
won't become an issue, for me to compete with wind and muffler, I
wanted it loud, louder, more louder, etc....
if you do happen to get stuck doing something basic out of need the
principals of good execution can help you out
these are the two improvement areas for 2012
it already 2013, so expect this thread to have a quick expiration date
the rockford is not really all that bad an amp,
but certainly limited in output with the lack of a transformer
that's why I say mathematically plan and do the best you can and then add
another.
these also run hot, having them in a place with a little moving air helps
I appreciate this dude. for some reason, the whole ohms watts, etc etc confuses the mess out of me. you think I could e-mail you or PM you a question about my setup?
Where does the remote wire hook to? I'm planning on using RCA hook ups from my Sony head unit and was wondering.
There should a remote/amp turn on wire on the harness coming from the Sony unit. You would connect that wire to the remote wire of the amp.
Discussion Starter #20
sweet spot on my MS60 was 39 ( outta 50 )
that is sort of the case with the DSX310 but it's a little hotter source, sometimes greater, sometimes less
so I may gradual down the gains by half or quarter clicks on each amp
I'll state right now tuning a loud system is difficult, because you almost instantly lose your objectivity, due to the volume levels
whaattt???
1 - 20 of 30 Posts
