1 - 12 of 12 Posts
Just installed the Interface Module for the Road Tech 665. Sometimes when it takes the volume down on the radio I hear the command and sometimes it just takes the radio volume down but there is no command that comes through.
Ideas on what is wrong? On what to check?
Thanks,
G
I just email road tech and garmen on it. the system is swithcing like i geting a input from the gps though the phone wires that what the nim wired into on the radio so i have them both turned up but the sound is not the same. if i find out more I will repost
Dear Ditch
Thank you for contacting Garmin International. I can definitely help you. Have you ever updated your software on your device?
Garmin releases system/operating software updates throughout the year. We would recommend running the WebUpdater program at least once every month to ensure that your device is up to date with the system software. If the WebUpdater program has not been installed on the computer please use the following link to start the download process for the program:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Your NIM might also need to be replaced by the Harley Dealership, but I would advise you to update your software first.
Let me know if you have any additional questions
is what I got from garmen
Don't get me started! Had my bike in for the same repairs. Garmin & HD tech never got it correct, I think I had the bike in for a total of 5 days. Finally I broke the fairing down myself and unplugged the said part and plugged the Garmin in to the AUX. Finally got back on bike and rode it like I stole it!
I don't have the 665 but my Garmin transmits on fm so I don't have to plug it into the radio. However it has the capability to do it.
Blue tooth, mp3, radio broadcast capability.
Refurb from best buy, $155.
Not waterproof. Just a baggie and that is fixed.
will buy alot of baggies for the $845 I saved from the price of the 665.
Final got my new NIM I have been told that it will fix the sound issues I have
Sent from my PC36100 using Tapatalk
Go the new part under from the dealer. Working like it should now.
Part number
83537-11a
Ditch,
You say your NIM works as it should. My question is...do you have a 1/4" jack running from the Garmin 665 to the HD radio face that runs into the AUX?
My thought was the NIM was to delete the need for an external wire to the radio face.
You still need aux jack but the in uncommanded volume changes have been fixed
Nim
Does it still open the mic on the headsets when directions are being given. Makes it difficult to hear the directions.
I have not had it going with the mic conected as of yet will try in the next few days but i think it will still turn the mic on due to the nim using the phone input on the HK radio
That's how mine works now. Had a hard time getting it to work but yes it works great. Just wish the AUX plug was not needed. When I read the description in the catalog (2012) it sounds to me that no AUX plug is needed. Until someone tells me different I'm just going ride. Life's to short to worry about it.
1 - 12 of 12 Posts
