1 - 10 of 10 Posts
Has anyone started using the new RF head unit for 98-13 RoadGlides? Wanting to know if you can actually see the display in sunlight?
Thanks in advance
These units are just now hitting the market, I doubt anyone has any real time data on them. I am curious about them myself.
Does anyone know if the RF PAUX will fit the gas tank console comm port? I want to buy the radio and use this as a means to play music off my memory stick.
https://www.rockfordfosgate.com/products/details/paux/
You can always get a usb extension cable and put it where ever you want. I have an Alpine 149 and ran a usb cable in the wiring tray under the tank to my tour pak and use my Ipod or thumb drive.
Finally got this unit installed. Biggggg difference over the stock unit. I have a Ultra and it's full plug and play. Of course you lose the CB and Intercom, but you gain Bluetooth, sound quality, and tunability. I had two after market amps, one for the front speakers and one for the rear. Didn't have to touch any of that, changed the radio. Because of the strong signal, I had to turn the Amps down. Awesome unit. You will not be disappointed with this unit.
So I guess I'll ask again, for those who have installed these in their Road Glides can you read your faceplate in broad daylight???
...can you read your faceplate in broad daylight???
The simple answer is yes. Now, I haven't gotten out that much since I put it in (winter in New England) so take this with a grain of salt - There's a "day mode" that essentially shuts off all the colors and turns the background white with black text for the station/song info; like a marine radio. I was able to see it the whole way to lunch and back. Couldn't say that for the Aquatic.
Do you have the key fob and security on your bike and did the new head unit work with that? Or is it only for bikes without security?
Found out that the security system for HD’s dont run through stereo head unit, but through another system. So no issue with changing the head unit if you have a HD security system.
1 - 10 of 10 Posts
