Anyone knows how can I accelerate my road glide? It shakes so much when I stop
That's what I am guessing too. I have the EITMS engaged in 100+ heat just for giggles, and for my inner thighs! :laugh: But don't like the lag (stumble) in throttle when taking off from a stop either. The EITMS isn't really necessary... if it was detrimental to performance or otherwise the MoCo wouldn't give the rider the option to turn it off. Try disabling the EITMS and see how you feel it runs.Definitely sounds like IETMS is enabled. I have NEVER used it... no need where I'm located.
I do that too, but still stumbles for me...When the EITMS is engaged, I blip the throttle when it's time to move.
Default is on in the ECM. The only way to set it to default off is either by a tunner (PCV or other) or having the dealer turn it to default off. Turning the key off should reset it to its default.I doesn't reset to "on" on mine when I shut the engine off. It only changes when you manually turn it on or off
Like I said. It doesn't "default" on mine. Never did. Only changes when I change it manually as specified in owners manual.Default is on in the ECM. The only way to set it to default off is either by a tunner (PCV or other) or having the dealer turn it to default off. Turning the key off should reset it to its default.
I could be wrong wouldn't be the 1st time, but I'm usually not wrong.
Sorry to say, but in this case you're wrong bro. >Default is on in the ECM. The only way to set it to default off is either by a tunner (PCV or other) or having the dealer turn it to default off. Turning the key off should reset it to its default.
Nice save"ish"! lol :grin:Well my 08 had to be turned to off default by the dealer. These new fandangled bikes with the CanBus obviously work different.
