Hi guys,
Have a quick question.
I am adding aset of 6x9 speakers on my lids and I bought the unibit (steadfast tool). I called up a local audio shop and they told me to drill about a 3/4 inch hole in diameter through the saddlebag in order to run the wire into each saddlebag.
Heres my question:?? Where can I find rubber grommets that will fit and set thru that saddlebag hole i created and is thick enough to stay on that wall. Harley told me they dont supply grommets any more.
The wire jacket is between 1/8' inch and 1/4' inch in length.
Reason because the red and black wires that Im gonna hook up to the positive and negative terminals of the speaker, I havent cut open the jacket yet. Both wires are still inside the black jacket uncut. (hope that makes sense?)
I need to find a 3/4' inch outer diameter rubber grommet with an inner diameter circle 1/8' inch (really tiny hole). It has to be 1/8' inch thin for the tiny hole.
Ive looked everywhere on the net and i cant find anything.
If you guys have a better suggestion, i would love to hear it.
Were all brothers here!
Thanx so much you guyz!!
John from boston
John from boston
