Ill apologize if there is already a thread for this.
Has any one put the new rushmore bags on a older Shark?
if so can you give me any tips and tricks?
thanks
thanks
All you have to do is adjust the mounts.
I elongated the holes on the front mounts by about 3/8". Then you just have to loosen the fronts up and set the bags in place, then tighten down the brackets. I also replaced the quarter turn pins with bolts and body retainer clips. It gives a little more wiggle room and they are more secure than the quick release pins.
I installed back bolt first loosened front mount started forward bolt and tightened front mount.. i also switched to nut plates and bolts.
you can find them at hardwood store or if i remember HD small parts has the set. Love the new bags.
have any of yall ran an old stlye tour pack with the new bags?
I'm wondering about clearance opening and closing the new bags.
I have a 2012 Ultra with the king tour pak. No clearance issues at all. The sales guys at a dealership were looking at mine with the new bags and were surprised because they had been told that the new bags wouldn't open with the old tour pak. I never even considered the possibility, to be honest. I suppose I could have raised the pak up on the mounting plate if I needed room.
If you get a reasonable deal on the bags and hardware then go for it. Great update. Makes the bags 100% more convenient. Easy to access at a stop light and even my wife can close them!
