1 - 20 of 20 Posts
Holy crap! That's gonna be a handful! I suspect you just won the bragging rights in your circle of friends. Mmmmmm I'd like to have about an hour with that!
My 2006 Road Glide. Just installed a S&S 124", Baker DD6 speed, 2 into 1 Thunderheader, PC III. 132HP, 144 Torque.
Reactions: Doug06rg
Can I ride it? Seriously I want to ride that beast!!!!lol
Reactions: Doug06rg
Nice arm stretcher.... What version of crate did you use the 585 or 640? Do you have inter-cooler and/ or any heat issues?
I have the 640 cams. I do not have an oil cooler. I did install an oil temperature gauge. As long as I am in the wind, the bike generally runs at 180-200 degrees (I live in South Florida). All is well with this monster engine!!!!!!!!!!
What's the highest the temps have gotten?
230 degrees when I was stuck in traffic on a day when it was 92 degrees out. As soon as I started rolling, the temperature decreases rapidly.
That seems pretty good to me. Thats a big engine making a lot of power. I would have thought it would have been higher.
congrats, looks like a blast to ride! What throttle body, injectors, and clutch upgrade did you go with? any problem with the install?
Nice numbers... Did you change the belt to chain drive? And what clutch you running?
You have to love the 124. Your torque is higher then mine but that's the difference between true duels and a 2-1. I put Drago's "H" pipe on over the winter and have a dyno appointment on 5-9 curios to see the difference.
1 - 20 of 20 Posts
