1 - 20 of 24 Posts
2008-up touring only.
162 hp
151 ft/lbs
10.47 cr
S&S .635 cam
Needs 70mm t/body
Black or granite
Bassani has the only pipe right now
4.635" stroke
4.425" hole
7.800" rods
low 30's mpg
Knew they had somthing up their sleeve.:)
Scott
My 124 is feeling a little lethargic ~ but I get great mileage.... Only 134/132.... Damn the slow Skunk..... Guess I know what the next one will be ~
That sounds vicious!!
Damn you, Mitch. I'm just about to swap in a 124 next month and you're telling me yours feels 'a little lethargic' now?!
You're an evil man.
I would definitely like to know about the price. ........ I hope it's really high so I won't have to think about it, lol.
Discussion Starter #15
With a little nudge in compression, and the use of the S&S .640 cam, I'd bet dollars to donuts that a SUBSTANCIAL power increase could be easily had, north of 170 hp and/or more.
BTW they come equpped with 1.725 roller rockers, and plus .020" pistons are available.
Scott
Only 144c.i. Gee you would think if they were serious they would have rounded it up to an even 150. LMBO
Scott
That's what I was thinkin about. A little bump in compression and those 640's should be killer.
162 hp
151 ft/lbs
10.47 cr
S&S .635 cam
Needs 70mm t/body
Black or granite
4.635" stroke
4.425" hole
7.800" rods
low 30's mpg
Scott
You can run Dragos "Fang Pipe" with this motor as long as you knotch your front heat shield to clear the cam cover.
Discussion Starter #19
According to S&S, the ONLY pipe available at this point, without hacking/cutting, is the Bassani.
I'd imagine that D&D has one coming quickly to suit the needs of that engine.........
On those 144's they have a 2 bolt style flange for a standard bolt up exhaust pattern as well.
1 - 20 of 24 Posts
