Just finished installing S&S True Duals on my 07 RG. Looks great and sounds great. Had one issue with the cross under pipe. The spacer brackets that mount the pipe aligned with the trans bolts but not to the welded bracket on the cross under pipe. Had to elongate hole on pipe bracket to line up to spacer. Wonder if anyone else had this problem? Did I miss something or just bad fabrication. Will give S&S a call shortly.
