1 - 4 of 4 Posts
The Motor Company lists 27200029 as only fitting 2014 - 2017 110" inch motors.
Anyone know what the difference is between a 2013 110" CVO Screaming Eagle and the 2014-2017 110" that would prohibit use of Harleys 58mm ?
I have a 2013 FLTRXSE2 110" Screaming Eagle CVO Road Glide.
Thanks in advance
They make them for the PreRushmore models. As for the parts number, I don't have on hand.
I am running the SE 58mm TB with 5.3 injectors that came with the 117" Pro Race Motor kit.
It should fit. FYI, you will have to upgrade to the 58mm backing plate too.
YB
I have the 58mm throttle body on my 2012 RGU with the 110 in it, so I know it can be done with the earlier models.
Harley Davidson 27713-08 Screamin? Eagle&reg Pro High-Flow 58mm EFI Throttle Body - Electronic Throttle LINK
Screamin' Eagle® Pro High-Flow 58mm EFI Throttle Body - Electronic Throttle - 27713-08
Genuine Harley-Davidson® Product
Click to enlarge image(s)
Harley-Davidson® 27713-08
Instruction Sheet
The biggest engines deserve the most fuel. This huge 58mm Throttle Body (8mm or 16% larger than stock) won’t leave your engine starving for more air. The one-piece throttle body features electronic Throttle Control technology. Just add your stock injectors or the Screamin’ Eagle Pro High-Flow Injector Kit P/n 27796-08 (sold separately). Stock injectors are recommended for engines making up to 100 rear wheel horsepower, Screamin’ Eagle High-Flow injectors are recommended for engines creating greater than 100 rear wheel horsepower. All EFI-equipped models require ECM calibration (sold separately). For race application only.
Fitment
Fits ’08-later Touring and ’11-later CVO™ Softail models.
SKU 27713-08
Weight 3.56 lb
Online Price $350.00
1 - 4 of 4 Posts
