1 - 4 of 4 Posts
Installed new set of 14" malo's. Went relatively well. Bike starts , runs fine, all buttons work. After a few miles, red light comes on for security system and stays on. Checked security pin# and that is still correct, when bike is shut off, goes through normal security shut down. This is a 2015 RG. Any ideas?
U frayed a wire sumwhere...uno slit it , and or cut thru ur wire insulation and the plastic stuff that's around it. does it again, stop and turn ur bars to the Left and the Right,...ur hitn wire to metal sumwhere!
problem solved
when putting right grip back on, didn't get brake lever and switch aligned correctly, lever had no contact with switch. once this was corrected, light stays off.
no codes came up and everything worked fine. glad it was this simple and not a damaged wire somewhere.
1 - 4 of 4 Posts
