1 - 2 of 2 Posts
Hi new to board I just swapped out apes for new ones with PM controls and switches on 06 RG. when I turn it on. Security system turning on by self. shut it off with fob. push starter security system turn on again. also doesn't seem to run fuel pump when turning on and light that tell you to wait to prime does come on either. very thing worked before and have checked new wiring twice. any thoughts would be great or I guess it off to the shop. thx snackwolf
It' just a guess but you need to check the emergency stop switch on the right switch housing. If the stop/run switch isn't working right or it's in the off position the fuel pump will not run. Once you get the fuel pump to run the bike should start, if it still doesn't turn over then check your clutch safety switch in the left switch housing.
1 - 2 of 2 Posts
