I am trying to decide if heel shifters play any part in the premature wear of a shifter shaft or shift arm. Over the past few years I have noticed bikes with heel shifters tend to wear out the splines on the shifter shaft and/or shifter arm faster than bikes without them. Is this my imagination? Just a coincidence? Or am I putting too much thought into this?
I’ve had several riding brothers have their shifter shaft/arm fail with no warning. We all already know about the issue with the shaft and/or arm wearing and failing. A couple of my friends found the shaft on their bikes worn while doing maintenance. At least one of them was running down the road when the shaft slipped out of the arm on the inside of the primary and fell off the motorcycle. All of these guys are riders and all of them maintain their bikes. All of them run and use heel shifters.
I have never used a heel shifter. If the bike has one on it when I buy the bike the heel shifter is normally the first thing to go when I get home. I have no real issue with them I just don’t use them. I have also never had a shifter shaft or arm wear out. I ride with a couple of other guys that don’t use heel shifters and normally remove them like I do. Neither of them have ever experienced a shifter part failure. Now I do check all the bolts in the shifter assemblies on my bikes regularly to be sure nothing has loosened up. Tighten anything that has loosened up and normally add a little blue Loctite to any I find loose. This may have something to do with why I’ve not had one fail to date.
So, what say you? Are heel shifters contributing to the shifter failures? Has anyone else noticed this relationship? Is this just a coincidence?
Just something to think about and discuss. 😊
