My current setup:
Both levers are extended models by Softbrake. You can't judge the height in this picture. The heel pad is only about 3/4" above the footboard. This image shows it better:
I went this route because it gives me more than the entire footboard for space. I don't have to lift a leg to heel-shift...just tip my heel up slightly and slide it over the pad. Foot stays planted on the board when shifting. I have the toe lever set lower because I don't need my size 13 boot to go under it. Down-shifts are fast and don't require me to lift my foot off the board.
You can see I replaced the oem linkage rod with the much better H-D replacement rod. The Heim joints on this rod are far more precise and dependable than the ball/socket setups that tend to get rickety over time and usage.
