1 - 3 of 3 Posts
Does anybody know what the actual size is of the stock riser bolts? I purchased the poly bushings and have heard you should run a slightly longer bolt then stock. Does anybody know the thread size and thread pitch?
On my 2016 Special when I changed to Arlen Ness Poly bushings the bolts I used were Grade 5, 3/4 head, 2¼ long, 1/2 with 13 thread per inch (coarse thread.). The instructions said to use a 2¼ bolt not longer.
Yes 2-1/4 is what i used tried 2-1/2 they were to long.
1 - 3 of 3 Posts
