1 - 4 of 4 Posts
Okay so this is out of a 2020 road glide special. Question is do I re-use this wire or run newer ones? I have the Stinger SVTK4681, should I pull the wire and grommet and run the wire from that kit, or will stock be ok?
Also what is this white box for?
Thanks in advance.
What I did on mine since I went with speakers that had lugs and not spade connections was to take the stock jumper wires out and ran new wiring from the amp straight through to the speakers. I installed a grommet in place of the conical sealed grommet that is attached to the OE jumper wires.
White box is like the HD version of Lojack I believe... bike wont start without it either They are doing away with it... short lived
1 - 4 of 4 Posts
