1 - 20 of 21 Posts
Shark of the Month December 2013
First off i wanna ask what 6.5 speakers everyone is using? I plan on putting two up front and two in the tour pack when sidecarcycles comes out with the adapters. Also, I have the hogtunes 7" subs in my lowers. Should i keep them or buy the CVO pods and put 6.5s down there as well. I am going to be running two PBR amps as well. Thanks in advance for the input.
The speakers you use depend on what you like, and how much you want to spend. If I had an unlimited budget, I'd go with top of the line Focals, But I don't. :(
seems like speaker preference is about as personal prefrence as seats / windshields or handle bars.
After hearing several setups at SW2, I went with a setup from Hawg Wired.
Im sure they are badass but im planning on possibly running three sets and at 250 a set i would have to sell a kidney. lol
Drago's sells everything from Hawg Wired less than the list price. Check with Frank you might be able to get them close to your price range. I have ZX speakers and amp and could not be happier.
That is badass but damn i would have around 1000 dollars in just speakers not including amps, stereo and wiring. lol Is there any kind of sell coming up? Or how about a Military discount or layaway since i wont be home from Afghanistan till May.
I did allot of research before I jumped in, basically my first parts list was an economical build using the Roford Fostgate amp and polk 6.5" speakers.
you'll want to make sure the speakers you end up with and the amp are rated for the same ohms.
Allot of people run this setup and report a major improvement over the stock system.
amp (comes in 2 or 4 channel):
http://www.ebay.com/itm/Rockford-Fosgate-PBR300X2-2-Channel-Amp-300W-/261125938753?pt=Car_Amplifiers&hash=item3ccc519e41
A member on the boards sells a custom mounting bracket for this amp as well, makes for a simple install.
I happened to get lucky and score a HW setup used at a great price.
Yeah i realize this. I am wanting to do the PBR 4 channel amps and i cant find anywhere saying that they are 2 ohm stable so im just gonna go with some RF 4ohm speakers or some Cadence 4ohm speakers.
Discussion Starter #14
Can someone share the part numbers to the CVO lower speaker pods and grilles with me?
The 4 channel PBR will not handle a 2 OHM load. There have been a couple members on here that found out the hard way.
Hawg Wired has their 25% off sale about once a year around XMAS, going on now - it doesn't seem to last long
If I were starting over, I'd get the Royal Flush and sell off what I couldn't use
BUT
MAY is a long time away, saying that spring CES in Vegas always brings new players to the table, or GOODIES
Hawg Wired is switching to a 150x2 chain 'em along system for amps, first of the year, about $300 /ea on the amps, $89 for the remote
basically what they have now, but lighter, no satellites
but the actual voicings on the ZX speakers are VERY GOOD, you'll hear stuff you've missed in the recordings
I'm in the process of swapping out my current set-up for Hawg Wired. Got a set of ZX's coming for my CVO pods, and then I'm going to order a set for up top. After I get them in place, if I'm not happy, I'll change amps and add some more!
Discussion Starter #20
I have decided on everything. Im going with a JVC deck with two PBR 4 channels amps and 4 sets of Cadence 6.5 speakers. Two in front where they belong, two down in the front fairing in between the bars, two in CVO lowers and also two in the rear tourpack pods.
1 - 20 of 21 Posts
