1 - 15 of 15 Posts
I have a 09 cvo rg with the JL audio 6.5 adapters and my speakers are hitting the outer fairing when I install it......how can I fix this? Does another adapter move the speaker in more so it doesn’t hit?
looking at the jl audio adapters on eBay they look to be offset as well. if your speakers are hitting your outer fairing, then i would rotate the adapters to put your speakers in a different position inside your fairing.
Thanks guys. The hawg wired is similar to the JL. I have the offset turned all the way in but the problem is the MMats pa601 magnet is wide.
I answered your PM also. Either the adapters aren't turned enough or different speakers. Mine fit no problem and I also have Dyna Mat on the inside of the fairing.
If you can, post a pic from the top looking down of what you have going on.
Those don't look like MMAtts speakers. Ive never dealt with those ones. Has anyone installed those before in a RG???
1 - 15 of 15 Posts
