1 - 11 of 11 Posts
speaker wiring question
Just making sure I got this correct.
Going to install 4 speakers with the Hawg Wired RS amp. I think I want to install them in series so this how I would wire all 4 speakers to 2 channels.
D.
What is the ohms rating of the speakers and amp?
If amp is 2 ohm, then parallel. If amp is 4 ohm, I still think you might want to go parallel, but thos with more knowledge should chime in. I found this site helpful http://www.bcae1.com/spkrmlti.htm
2ohm amp and 4 ohm speakers, definitely parallel, perfect match.
1 - 11 of 11 Posts
