1 - 2 of 2 Posts
Checked for codes, none.
Checked VSS for metal shavings, none whatsoever.
Replaced VSS, no change.
Still lights up but not sure about odometer changing, wasn't watching.
Do I have a grounding problem or speedo shot?
Any help is appreciated.
It' hard to say if the speedometer is shot or not. The best way to check the speedometer would be to put another speedometer in and see if everything works. If you have a friend that has a touring model bike you may be able to swap out speedo's just long enough to see where the problem is.
1 - 2 of 2 Posts
