I have everything to do my stage 1 but a map. I have a power vision from my 2013 but running a different set up and now I have an ultra. I will run DD head pipe and reinhart 4" mufflers. Doing the RSD air cleaner as well. Fuelmoto said they would not sell me a new license agreement because I did not get the PV from them.
My question is where can I get a good map and how does it work? Do they email them? Sorry I am very ignorant on this. I had a friend do my system last time but he is not around anymore.
I really want to do this myself and become more knowledgeable about the bike. Thanks
If I'm not mistaken, that tuner is married to your old bike, You'll need a new license not just a new map. You'll need to contact Dyno jet to purchase a new license to use it on the new bike.
Your probably better off just buying a new one off FM that will come with their support. It's not that much more for new.
First of all, you do have all the cables as well as the CD with the WinPv software, or at least the WinPv program on your computer right? If so, your first order of business would be to hook your PowerVision up to your computer and do an update. (The downloads link I provided has information on how to do that if you're not familiar with the process). I believe the update will load the latest tunes to your PowerVision. Alternatively you can download the tunes from Dynojet's website to your computer, to the WinPv program and finally to your tuner. The instructions available from their download page will help you. If you're unsure which tune to select, contact their tech support. They're friendly and helpful.
Neither Fuel Moto nor Dynojet might have a map for your exact configuration but they'll get you close enough at which point you would run a few Autotunes to dial it in a little better.
If you purchase a PowerVision from Fuel Moto, they'll load a tune based on your configuration. Thereafter, if you make changes or want a different map, you request it from their website. They'll then email you a tune. Be patient. It takes about 3 working days, but they'll it get to you. They've got a special on the PowerVision this month, so if you wanted to take that route, you could always sell yours to help pay for the one you get from Fuel Moto.
Might be worth a call to Dynojet to see what they're charging for a license, and save yourself a couple hundred bucks. Visit their website and read the FAQs.
For tunes, follow the link below. Plug in you bike's information (year, make, model, engine size) and it will populate the tunes available for your bike. If I remember correctly, these same tunes download to your PowerVision when you do an update.
Power Vision Tunes
The link below should answer some of your questions about obtaining a license from Dynojet.
http://www.powercommander.com/downloads/Support-Released/Manuals/powervision_dual_tune_license_program_intructions_3_28_2013.pdf
This link takes you to their downloads page. The downloads take mere seconds, they're informative and should be able to answer most your questions.
Power Vision Downloads
If you are currently riding a Rushmore, you most likely will need a new cable to connect the PV to the ECM. I had to order a new cable when I went from an 09 to a 15.
Power Vision Tunes
I wanted to thank you for this info. I have been so damn busy with work i did not have time to respond. I finally got my pipes installed and called Dynojet for my PV. They sent me a new cable and the new license agreement. Flashed it today and managed to get about a mile ride before the flipping rain started. Awesome customer service! Thanks again!
