1 - 10 of 10 Posts
Installed dragos hpipe and 4inch dragula mufflers along with an arlen ness big sucker started the bike up yesterday and the engine light came on. Is this due to the new mods?
I have the power vision from fuel moto with a map for the stage one mods will the power vision correct the engine light issue or give me a code?
Tia
Masque
The engine light means you have a DTC code. You do not need to hook up the power vision to check and clear DTC codes, there is a sticky on how to check and clear the DTCs in the troubleshooting section.
You may have to change the base map on the powervision because of the mods.
1 - 10 of 10 Posts
