1 - 4 of 4 Posts
OK here goes. I have a 13 ultra that has tru duals, hi flow air cleaner, and a automatic tuner. When I had the local dealer install cams they put a download in. My question is this, Should I put back on the tuner or just go with the download. And if I do put on the tuner will this take my download off the ECM if I remove the tuner. Sure hope that made a lick of sense.
What kind of tuner are you using?
If the bike runs good and you are happy then just stick with the download. If you are having tuning issues then use the tuner. In most cases a tuner will help the bike run better and cooler so it would be good to have the bike dyno tuned using a tuner.
1 - 4 of 4 Posts
