got a 2015 RGS around 25000 mls on it and just had a stage 3 kit put on it.. Put around 300 miles on it so far in the break in and keep hearing tapping sounds from the engine. Is this normal while I break it in or should I let the dealer know about it before it gets worse or I do damage to the motor.. hear it in all RPM ranges,, worried.
Might be normal, might not depending on the components that were installed. Sometimes a cam can add a little top end noise.
Go back to who did the work and have them take a listen.
Keep us posted.
Take it back under dealer warranty my 2010 same thing
bent pushrod no charge no issues in 12000 miles since wait oil pan gasket replaced this winter drop off helped offset winter storage cost
I would have it checked to be on the safe side. I know that the higher lift cam of the stage 3 kit will cause a little more valve train noise than you had previously. Did you have a high flow air cleaner installed at the same time? You will get hear some noise from the throttlebody now that it's more open than it was.
I would think if the lifters were new and the pushrods correctly adjusted, the top end noise should quiet down - mine did. Have you tried adding Rockouts? They help take away the ticking up top. https://www.rockout.biz/
keep an ear on it. if it goes away after warmed up it's prolly just a pushrod adjustment.
if it were my bike that just had the work done i'd take it back and have them check it.
