1 - 20 of 20 Posts
M
Guest
I just "upgraded" from an '04 to a 2010. The damn thing is so stiff that my wife won't ride it. I immediately put a hammock seat on it and it helped some. If I hit a small bump, like an expansion joint, the thing jams my back straight up into my head. It feels like a hard tail.
I have gone from 0 psi to 50 psi on the rear and everywhere in between. This thing doesn't ride nearly as good as the 2004. My dealer says it's just the new frame and suspension they put on the FLs in 2008. I can't believe it's this bad. It's so stiff that it's no fun to travel on. After 43 years of touring, I'm thinking of going back to something else.
It almost feels like it's bottoming out but the bumps aren't that severe - small bumps jolt me. I really think it's just stiffer than heck, which is probably why it corners so well. A chug hole rattles my brains. Is there any decent aftermarket solution?
I dont no of any aftermarket solution,they are out there, but ask your dealer(pressuming you bought new)to change rear suspension to 011 Roadglide Ultra suspension. I had a 2005 FLHTCSE2, low profile touring suspension, IT SUCKED! Did x-actly as you have described. Man I put a sidekick seat on my 2009.Its looks like a Ironing Board,lol, w/a little bit of flair. I put 45lbs. pressure in my rear shocks, and dude it GLIDES!
I've had great results with my Progressive 940 shocks.
Let me add one other thing, the guy who bought my 2005 FLHTCSE2 complained of the x-act same thing to the dealer I did my deal with, and they replaced the rear shocks at no cost to him. He said it took care of the problem! I dont no if there has been a problem w/these in paticular but from 2005 to 2010 I think they switched to a different low profile suspension.
The 2010 have a shorter shock than the earlier models and also the2011. Just chane the shoch to the longer one and you will be fine. Duane5157
I went from an 07 to a 2010 and experienced the same thing. My wife would be in pain after riding on the back and hitting bumps and dips. Take your tire pressure back down to 40 psi and put 27lbs of air into your rear shocks. It should make a huge difference!
M
Guest
Discussion Starter #7 (Edited)
More on Mike's Stiff Ride
At the advice of my dealer, I replaced the "short" shocks on the 2010 RG Custom with longer ones from another model (an Ultra Classic, I think). Anyhow, $426 later it rides just the same. I wish I would have spring for some Progressive 940s and tried them. I still might suck it up and order some 940s but I'm a little gun shy right now.
Based on how mine rides, I can't believe that there isn't a general uproar on how stiff these bastards are.
BTW BDMastiff, I normally run 40 PSI on both tires and even with the longer shocks, I tried shock pressures from 0 to 50 in 10-psi increments. Still jumps over expansion joints like a frigging pogo stick.
Has anybody tried changing the shock oil ? Put some real oil in there and get rid of that fish oil :D It sure made a difference on mine, they come stock with 5wt and I went to 10wt Motorex at 10.8 ounces. gives you a little bit better dampening.
Ow ya I forgot I run 15 to 18 P.S.I. two up and 5 P.S.I. Solo
ifin we got her loaded up for a long trip I'll run 20-22 P.S.I.
mine has the 13" airs on it, hope this helps.
I have the same issue. Going from my 06 FLH to my 11 FLT the ride is much harder. When I put ten psi in the rear like my FLH my FLT rides like crap. I have been running twenty psi. Its a bit better. Try bumping up the air in the back.
I have the same problem with my 2010 RG. It feels like a hard tail. This X-mas i'm installing a set of progressive mono-tubes for the front forks, and on the back I'm installing the 440 shocks. does anybody have any expierience with this combo??? Thanks.
My 2010 shocks SUCK also.. I want to go with progessive mono-tube in the front and 440 or 940 in the rear. DOES ANYBODY HAVE ANY KNOWLEDGE IF THIS IS GOING TO WORK OR NOT??????
Well I know the 940's work great in the rear. Haven't gotten around to the front yet.
Why did you go with the 940 verses the 440??? do you know what the difference is?
I didn't want air shocks. Go to Progressive's site, they show all the differences.
My 2010 FLTRX was so bad I took it back to the dealer. The mechanic took it for a ride and couldn't believe how bad it rode. He called HD and they OK ed new shocks. I asked for the longer Ultra shocks and got them. It rides great now.
I have the same problem with my 2010 FLTRX, rides like a hard tail. This really sucks. The front end has no dampening at all. Just change the psi in the rear down to 15 psi, will see if that helps. The front end is still a pain....
Get some proper shocks, I do all my long distance travelling 2up and I cannot begin to tell you how much I hated those POS air shocks. My wife is maybe 110lbs and I'm coming in at twice that.... with luggage and a Dakota bag outboard on the tour pak evey time we hit something at speed I zeroed or close to... the air shocks and we had a buckboard on our hands!
Progressive 440's, Touring Link, Mono Tube fronts - whole new bike on my hands. The wife was harping to sell the shocks with all my other swap meet stuff and I refused to inflict that crap on some poor hapless soul along with my lowering blocks - nobody 2up should endure that crap ;)
Dirk
[/IMG]
[/IMG]
When I first bought my '10 I posted on here about the crappy ride and was flamed. I feel redemption now.
It took a while to sort out the air pressure but I eventually settled in keeping it above 30 psi and that seemed to do it for me but my '06 still rides much smoother.
I recently bought an Infiniti FX50S which is the high performance handling version of their SUV and it is very stiff and rough, but man does it take corners. That's the price to pay for increased handling performance.
this. unless you have really short legs (like me) and need the shorter suspension, if you go with the stock height of 13 inch, your ride comfort will increase greatly. especially, if you go with a good aftermarket 13 inch shock.
whatcha mean 'back down to 40'? isn't it supposed to be 36?
the 940 is supposed to give you athe ride of a 13 inch shock, with the stance of a 12 inch. has something to do with the rebound damping.... like thunderbueller said, check out the progressive website, they will give you tons more info on how this works.
1 - 20 of 20 Posts
