*****All items are sold*****.
Upgraded to a BT system with aftermarket HU so everything else must go. Everything works perfectly, just don’t need it anymore since I upgraded.
The stock HU is off 2013 RGC and is available by itself or with the speakers/amp. I would prefer to keep the speakers/amp together, but will consider splitting them up.
Speakers are 170W 7.25” J&M Rokker XT series with built in tweeter/midrange cone. Includes speakers, adapter rings, grill with built in tweeter cone and all the screws originally provided by J&M.
Amplifier is RF PBR 300x2, it was only installed for a few months. I used plenty of wire so you won’t have any problems reaching anything no matter where you decide to mount the amp. I used the stock speaker connectors so all you have to do for the output is plug your speakers in. The input is setup for high level inputs from the speakers. I left the spade connectors on so all you need to do is crimp spade connectors to your stock speaker wire for the input. RF sells their install kits separately so you will need power/ground wire if you don’t already have an amp installed. I left the gain and frequency pass set like I had it for the stock HU, so it should be pretty close. If you’re running an aftermarket HU definitely turn the gains down before you crank the volume up the first time.
Stock HU - $275 shipped to lower 48
Speakers and amp - $265 shipped to lower 48
