Sorry folks, couldn't find this via search or youtube. Do you find you get a more complete oil drain when draining on a stand/lift or on the jiffy stand? All three holes.
Wade
I find more comes out of the primary when it’s on the jiffy. The tranny seems to drain best straight up. The oil drains straight up, but if you lean it on the jiffy after more seems to still come out. What I do is drain all three straight up on my table lift and then I will loosen the wheel chock and lean it slightly to the left while the jiffy is down.
Thank you Sir. I've changed my own most of the time, well, all except for the first maintenance, but it's just a question I've thought about many times.
Wade
I have been doing it straight up on the lift. I did by a jack and will try it slightly elevated to see what that does.
