1 - 3 of 3 Posts
They will work...
Anyone on here using these bulbs?
https://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-switchback-led-bulb-dual-function-60-smd-led-tower-a-type-bay15d-retrofit-car/1915/4479/#tab/Specifications
I have heard good things about them, but i wanted to see if anyone with a RG had pics or input about them
They will work and look just like the OEM bulbs, responding faster and require a load equalizer. I wanted the light reflector area to be full of LEDs, I did the migration to LEDs in stages and bought the Kuryakyn equalizers, then went to the Custom Dynamic Dynamic Ringz in front and Full Red inserts in the rear. They now offer a yellow/red version of the Ringz for the rear. But I like all red lights to the rear anyway. The Kuryakyn load equalizer set up will let you replace only the equalizers as I have found regardless of the manufacturer they only last two years. I just installed the new alarm compliant equalizer and I only needed one for all four turn signals!
https://www.customdynamics.com/category/led-turn-signals/harley-davidson/led-inserts
http://www.kuryakyn.com/products/763/load-equalizer-adapters - They used to sell the harness with the resistors, now it piece by piece.
You won't need a load equalizer if you have a RG with a can system, so Rushmore style bikes. There is a learn process you can do with the bike, ask your dealer as I don't remember off hand.
1 - 3 of 3 Posts
