1 - 4 of 4 Posts
I just bought this exhaust for my 2016 FLTRXS. I have been trying to find out what the increase in HP and torque I will get after putting it on with a high intake air system and the FP# fuel pack. Need to know where I can find this info and/or anybody that has an idea.
Not trying to be a jerk but, that may be because no one can tell you that. Depending on the map, it may go from loss of performance to "who knows". That is not a real common exhaust so, you may not find a map that is specifically for your configuration. Best bet is try to find a map that is close and go from there.
The only person that's going to be able to tell you what numbers you will get is your dyno guy.
Thanks. I will probably end up talking to V&H and try to get the most similar map from them and tune it that way. After a few fuel tanks I will do the auto tune. I did that with my 2012 Street Glide that had a Thunder Header.
1 - 4 of 4 Posts
