I hard wired the whole DAMN TBW and had to many and cut off the main harness under the Hood. Anyone know the color match up on this? Where the TBW plugs into the harness under the HOOD :confused:
Welcome to the group. What model bike do you have? Did you reuse the original TBW or the SE version? There are 2 different wiring color schemes. NEED DETAILS.............:confused:
tbw
11 RG custom, I reused the original TBW but added a 18 inch extension. When I got to the plug without thinkin I cut it. cut the green plug off and soldered those wires up. So now Im down to the plug under the Hood.
Here is plug layout for both wire sets. Keep in mind that you are looking at the front of the plug not the place you put the wires. Pay attention which sleeve you are using. Also you are talking about the fairing (inner and outer).
