The Tour Glide / Road Glide History - a complete information guide
315K views 291 replies 127 participants last post by  NCGlider
#1 ·
I tried to make a wikipedia page, but they shot it down due to lack of references. What they don't realize, there is no references as the history has not been well documented. If you do a google search for Road Glide history, this forum is the only thing that comes up.
If you have more to add or corrections, please reply and I will edit so all info is good and up to date. I would love to have listed all color choices for each year, so please help me out there where you can. Most of the initial information came from forum members RoadGlideRider and JacktheBagger - thanks for sharing your knowledge gentlemen. A lot of the missing info is going to take some of you experienced guys to fill in the blanks for me, as information is just not out there on the web.
_________________________________
The Harley-Davidson '''Road Glide''' or '''Tour Glide''' is an American made touring motorcycle that was first put into production in the year 1979. The Tour Glide was different then any H-D models before, in that it had a fixed fairing that was attached to the frame and did not move with the handlebars.
Today the Road Glide is one of the most popular motorcycles in the custom bagger world, and for long distance touring.
The shape of the fairing is often referred to as a "Sharknose" fairing due to the resemblence of a shark.
First years - Tour Glide
The Tour Glide was introduced in 1979 and only 19 FLT's were produced that year. In the following year Harley produced 4480.
The 1980 Tour Glide was the first to have the 5 speed transmission and 3 point rubber mounted engine. The motorcycle also had a rectangular steel back bone , and tubular frame, twin 10" front disc, single 12" rear disc and an enclosed final chain drive. The bike was powered by an 82ci (1338cc) Shovelhead with a bore x stroke of 89 x 108mm and had a wet multiplate clutch, 5 gallon gas tank and the bike weighed 725lbs.
The 1981 model brought a VfireII electronic ignition, lower 7.4:1 C.R., longer valve guides, extra oil drain lines from the rocker boxes, revised valve guide seals, and a Girling rear brake caliper.
In 1982, the FLT got new handlebars and seat, primary chain oiler, higher output alternator, and locks for the luggage.
1983 only brought a lower seat, and stiffer suspension.
From 1979 to early 1984 the tour glide was powered by the Shovelhead engine. In late 1984 until 1996 the motorcycle was powered by the Evolution engine. The early 1984 models had a shovelhead bottom end with an EVO top end.
There was never a Police FLT Model. Only FLHT, FXRP, XLP, and Dyna Police models.
It is known that the 1984 through 1988 models (at least, maybe more) had air resivors in the crash bars for air assist to the front fork springs. The 1985 model was changed from a final drive chain to a belt.
The Tour Glide came without a Radio or gauge mounting positions made into the fairing. To add a radio, you would need to purchase a Radio Caddy from Harley, or several after market companies. Some after market caddys came with the gauges mounted in the radio aaddy. To add Harley gauges, Harley sold ones that required you to drill a hole in the fairing and mount them there. Harley introduced the Radio Caddy for the Tour Glide fairing and was stock beginning with the 1986 model year. It is the same year Harley had the radio in the Inner/outer fairing on the Electra Glide. It was produced by Radio Sound. That radio was only used in the 1986/87 model years.
The only major change made that didn't change the name of the model line was to move the turn signals from in the fairing to outside and attached to the lower mounting supports and this happened in 1988.
1989 the "Ultra" model was introduced along with the base FLT model. The alternator was bumped up to 32 amp for 1989 and it also had a one piece pinion shaft and right flywheel.
The FLTCU model came standard with cruise control, a CB radio, intercom, front and rear sound systems, and fairing lowers, and two tone paint jobs. The standard FLTs were solid colored bikes. A sidecar option was available for the FLTCU, but only 15 were made in 1989. Total production for 1989 is believed to be 603.
The Tour Glide's last year of production was in the 1996 model year, and also the first year for the fuel injection option.
There was not any FLT models produced for the 1997 model year.
Road Glide years
With the introduction of the 1998 model lines, Harley introduced the FLTR Road Glide. This was using the same frame and motor assembly as the Electra Glide, as before, but with a completely redesigned fairing. It included the radio and gauges mounted in the fairing in areas that were made for this purpose. This inner and outer fairing has not changed for the entire production run of the Road Glide. From 1998 to present it has remained the same.
The fairing changed slightly and this was the last year for the Evolution engine. In 1999 Harley Touring models got the Twin Cam engine that bumped the displacement up to 88".
From 1999 to 2003 the motorcycle had very minimal changes.
In 2000 and 2001 Harley offered CVO Road Glides, the FLTRSEI and FLTRSE2.
2004 brought the change from cassette tape to compact disc, and in 2006 the radio manufacture changed from Radio Sound to Harman/Kardon.
2007 the engine displacement increased from 88ci to 96ci and Transmission to 6 Speed, and all Touring Models became EFI standard.
In 2008 the fuel tank increased to 6 Gallons. Throttle changed to Throttle By Wire, brakes changed to Brembo Brakes, and an ABS option for all Touring Models.
2009 brought the new frame, rear tire changed to 180 wide rear tire and 17 " front tire. This was the last year of the Road Glide (FLTR). After many years Harley Davidson brought back a CVO Road Glide in 2009 (FLTRSE3).
Custom and Ultra years
After many rumors that the Road Glide's last year was going to be the 2009 model year, 2010 models came out with a newly designed Road glide called the Road Glide Custom and designated model FLTRX. The bike was basically the same as a Street Glide, just with the shark nose or fixed fairing.
The 2010 models was the first and only year to offer a 2 into 1 headpipe.
2010 was also introduced with 18" front tire, lowered rear end with newly designed tail lights, doing away with the center brake light in the middle of the rear fender.
In 2010 Harley redesigned the fairing mounting supports. They were redesigned to move the fairing up and re-angle the fairing to make the fairing accept the vented lowers that are now being used on the Electra Glide. Before this models change, the Road Glide required a different lower fairing from and of the "Batwing" or Road King models lines.
Cruise Control was made optional (controls removed from handlebars).
2011 Road Glide Custom (FLTRX) same as before with new colors and 103ci motor option and a 2/1/2 headpipe. The Road Glide Ultra (FLTRU) was introduced with a 17" front tire and has the TwinCam 103ci motor. Harley also produced a FLTR CVO Road Glide Ultra (FLTRUSE) with 110ci engine and 18" front and rear tire.
2012 saw both the FLTRX and FLTRU models return, and a FLTRXSE in 3 color offerings.
2011 was definatley a big year for the Road Glide, along with 2012 and the best kept secret in the Harley Davidson line-up, seems to be finally getting some well deserved respect in the touring community.
2013 was another great year for the Road Glide, with the Custom and Ultra returning with new color offerings. Also the FLTRXSE2 returned with addition speakers in the saddlebag lids, 2 paint offerings and the 110 year anniversary edition CVO Road Glide. The FLTRXSE2 came with Harley's new LED lighting for the Road Glides.
#71 ·
Thank you sir,.. updated my info. At a stalemate of sorts on info,. exhausted all my resources and hoping the right people will find us and share info.
#72 ·
Don't forget. . .
Don't forget to make mention of the FXTR.....the Roadglide's "first cousin" and still a Shark! I saw this pristine example Saturday at Tarpon Springs Fl bikefest and seriously considered grand theft. I used to have an FXDXT that I want back badly (but not at the expense of my Roadie) and applaud the MoCo for trying it again with the Switchback. Anyway, the FXTR bikes were awesome...I want one but can't afford another bike, even If I could find one in this great of a state of repair!
#82 ·
Guy right around the corner from me has one almost identical to this one color and all...it sat outside in the driveway all summer long never moving out being covered. It is in beautiful condition too I considered asking if he wanted to sell it but my wife said no to another bike right now.
#75 ·
I have contemplated adding that bike, and info about the vetter fairing that was the "original" sharknose type, but there is some info about that already. Your right, its related to the bike,.. but then again its not really a road glide. You can trace the tourglide geneology straight to the road glide,. but the FXRT is a distant cousin by marriage in a way. If I can get someone from the Moco to give me the full history, and the FXRT did indeed play a huge roll in creating the tourglide I would add it.
#87 ·
Actually, the FXR line grew out of the FLT line. IIRC, it came down to developing the FXR frame (from the FLT work already done) OR developing/going forward with the Nova Project (in conjunction with Porche?).
Well, the Nova Project was cut, for the time being, and the FXR was produced. Later, the V-rod was brought into the picture.
Later...
Brewster...
#84 ·
Chain, a couple things.... you wrote that the 2-1 headpipe was 2010 only, but I believe that it still came standard on 11s unless you got the power pack option.
Pacific Blue was a one year only color (2007), might be worth posting a pic of that bike for the photos (my bro has one).
I have a book called the ultimate Harley Davidson with a nice color 2 page spread on the 1989 FLTC. If you want me to send you some hi res pics of the two pages, shoot me your e-mail.
#93 · (Edited)
#86 · (Edited)
There's an interesting prelude to the birth of the FLT series and, naturally, Elvis owned one...​
The HD military model "Liberator" nickname was selected as the name of a fairing add-on for the FLH. It was a joint venture between Craig Vetter and Harley. With Harley endorsement, Vetter began design in '73 and after reviewing the final prototype, Willy G. approved the program.​
It was introduced as a new accessory in 1975...​
...but full production didn't begin until '76...​
...and then a devastating fire at the Vetter factory halted production in Jan of 1977.​
For more info, see http://www.craigvetter.com/pages/vetter_fairings/Liberator.html
#89 · (Edited)
Great discussion and I keep learning stuff I never knew - I've got an '81 FLT, originally 5 speed shovelhead with enclosed chain. A couple of years ago I removed the fairing and changed to the FLHS look, put in an Evo with the original 5 speed and went to rear belt,newer late 90's Road King wheels and brakes, solo saddle. Makes a great "sport bike" and I can always change it all back if I want. Love these old barges, and it is a fun alternative to my merlot '11 FLTRU. Good work guys.
#91 ·
Why did ya dump the shovel head? Much rather have the shovel than the Evo especially for a second bike.
#90 ·
... ran into this promotional language from the MOCO re: the '01 FLTR;
" Welcome to year three of a brand-new look for Harley-Davidson touring. Introduced in 1998, the Road Glide is built around a frame-mounted fairing and low windshield. Leading the way are distinctive dual oval headlamps with automotive-style reflector optics. We keep the rest of the styling clean and uncluttered, a pure custom look. Shining through is a chrome and wrinkle black Twin Cam 88 engine, available with a traditional carb or sequential port fuel injection. Of course you also get the latest touring features, the heavy-duty wiring harness found in our Ultra Classic. So you can keep it simple or load one up with everything. To go, of course. "
#92 · (Edited)
I agree but all I got at first was the bare frame with fairing, tank, side covers, bags - already had a rebuilt Evo and a bunch of FXR bits and pieces ( tranny, etc.) and newer swingarm, brakes, front end and wheels so just went the easy way. I did have the fairing on for a while however it rattled too much for my taste so it's now retired. Will replace the Evo with a shovel if and when I run across one, because I do miss having a shovelhead around.
