The Tour Glide / Road Glide History - a complete information guide
1 reading
315K views 291 replies 127 participants last post by  NCGlider
#1 ·
I tried to make a wikipedia page, but they shot it down due to lack of references. What they don't realize, there is no references as the history has not been well documented. If you do a google search for Road Glide history, this forum is the only thing that comes up.
If you have more to add or corrections, please reply and I will edit so all info is good and up to date. I would love to have listed all color choices for each year, so please help me out there where you can. Most of the initial information came from forum members RoadGlideRider and JacktheBagger - thanks for sharing your knowledge gentlemen. A lot of the missing info is going to take some of you experienced guys to fill in the blanks for me, as information is just not out there on the web.
_________________________________
The Harley-Davidson '''Road Glide''' or '''Tour Glide''' is an American made touring motorcycle that was first put into production in the year 1979. The Tour Glide was different then any H-D models before, in that it had a fixed fairing that was attached to the frame and did not move with the handlebars.
Today the Road Glide is one of the most popular motorcycles in the custom bagger world, and for long distance touring.
The shape of the fairing is often referred to as a "Sharknose" fairing due to the resemblence of a shark.
First years - Tour Glide
The Tour Glide was introduced in 1979 and only 19 FLT's were produced that year. In the following year Harley produced 4480.
The 1980 Tour Glide was the first to have the 5 speed transmission and 3 point rubber mounted engine. The motorcycle also had a rectangular steel back bone , and tubular frame, twin 10" front disc, single 12" rear disc and an enclosed final chain drive. The bike was powered by an 82ci (1338cc) Shovelhead with a bore x stroke of 89 x 108mm and had a wet multiplate clutch, 5 gallon gas tank and the bike weighed 725lbs.
The 1981 model brought a VfireII electronic ignition, lower 7.4:1 C.R., longer valve guides, extra oil drain lines from the rocker boxes, revised valve guide seals, and a Girling rear brake caliper.
In 1982, the FLT got new handlebars and seat, primary chain oiler, higher output alternator, and locks for the luggage.
1983 only brought a lower seat, and stiffer suspension.
From 1979 to early 1984 the tour glide was powered by the Shovelhead engine. In late 1984 until 1996 the motorcycle was powered by the Evolution engine. The early 1984 models had a shovelhead bottom end with an EVO top end.
There was never a Police FLT Model. Only FLHT, FXRP, XLP, and Dyna Police models.
It is known that the 1984 through 1988 models (at least, maybe more) had air resivors in the crash bars for air assist to the front fork springs. The 1985 model was changed from a final drive chain to a belt.
The Tour Glide came without a Radio or gauge mounting positions made into the fairing. To add a radio, you would need to purchase a Radio Caddy from Harley, or several after market companies. Some after market caddys came with the gauges mounted in the radio aaddy. To add Harley gauges, Harley sold ones that required you to drill a hole in the fairing and mount them there. Harley introduced the Radio Caddy for the Tour Glide fairing and was stock beginning with the 1986 model year. It is the same year Harley had the radio in the Inner/outer fairing on the Electra Glide. It was produced by Radio Sound. That radio was only used in the 1986/87 model years.
The only major change made that didn't change the name of the model line was to move the turn signals from in the fairing to outside and attached to the lower mounting supports and this happened in 1988.
1989 the "Ultra" model was introduced along with the base FLT model. The alternator was bumped up to 32 amp for 1989 and it also had a one piece pinion shaft and right flywheel.
The FLTCU model came standard with cruise control, a CB radio, intercom, front and rear sound systems, and fairing lowers, and two tone paint jobs. The standard FLTs were solid colored bikes. A sidecar option was available for the FLTCU, but only 15 were made in 1989. Total production for 1989 is believed to be 603.
The Tour Glide's last year of production was in the 1996 model year, and also the first year for the fuel injection option.
There was not any FLT models produced for the 1997 model year.
Road Glide years
With the introduction of the 1998 model lines, Harley introduced the FLTR Road Glide. This was using the same frame and motor assembly as the Electra Glide, as before, but with a completely redesigned fairing. It included the radio and gauges mounted in the fairing in areas that were made for this purpose. This inner and outer fairing has not changed for the entire production run of the Road Glide. From 1998 to present it has remained the same.
The fairing changed slightly and this was the last year for the Evolution engine. In 1999 Harley Touring models got the Twin Cam engine that bumped the displacement up to 88".
From 1999 to 2003 the motorcycle had very minimal changes.
In 2000 and 2001 Harley offered CVO Road Glides, the FLTRSEI and FLTRSE2.
2004 brought the change from cassette tape to compact disc, and in 2006 the radio manufacture changed from Radio Sound to Harman/Kardon.
2007 the engine displacement increased from 88ci to 96ci and Transmission to 6 Speed, and all Touring Models became EFI standard.
In 2008 the fuel tank increased to 6 Gallons. Throttle changed to Throttle By Wire, brakes changed to Brembo Brakes, and an ABS option for all Touring Models.
2009 brought the new frame, rear tire changed to 180 wide rear tire and 17 " front tire. This was the last year of the Road Glide (FLTR). After many years Harley Davidson brought back a CVO Road Glide in 2009 (FLTRSE3).
Custom and Ultra years
After many rumors that the Road Glide's last year was going to be the 2009 model year, 2010 models came out with a newly designed Road glide called the Road Glide Custom and designated model FLTRX. The bike was basically the same as a Street Glide, just with the shark nose or fixed fairing.
The 2010 models was the first and only year to offer a 2 into 1 headpipe.
2010 was also introduced with 18" front tire, lowered rear end with newly designed tail lights, doing away with the center brake light in the middle of the rear fender.
In 2010 Harley redesigned the fairing mounting supports. They were redesigned to move the fairing up and re-angle the fairing to make the fairing accept the vented lowers that are now being used on the Electra Glide. Before this models change, the Road Glide required a different lower fairing from and of the "Batwing" or Road King models lines.
Cruise Control was made optional (controls removed from handlebars).
2011 Road Glide Custom (FLTRX) same as before with new colors and 103ci motor option and a 2/1/2 headpipe. The Road Glide Ultra (FLTRU) was introduced with a 17" front tire and has the TwinCam 103ci motor. Harley also produced a FLTR CVO Road Glide Ultra (FLTRUSE) with 110ci engine and 18" front and rear tire.
2012 saw both the FLTRX and FLTRU models return, and a FLTRXSE in 3 color offerings.
2011 was definatley a big year for the Road Glide, along with 2012 and the best kept secret in the Harley Davidson line-up, seems to be finally getting some well deserved respect in the touring community.
2013 was another great year for the Road Glide, with the Custom and Ultra returning with new color offerings. Also the FLTRXSE2 returned with addition speakers in the saddlebag lids, 2 paint offerings and the 110 year anniversary edition CVO Road Glide. The FLTRXSE2 came with Harley's new LED lighting for the Road Glides.
#208 · (Edited)
Painted part numbers have letters following the last two numbers in the part number. Painted parts are listed in a separate painted parts book the dealers have but not available for the public. If you have a part number, it is easy for the dealer to look it up and special order it. But if the part is obsolete, it can’t be ordered. If you have (or can get) one, you may can order the specific color and have it painted.
Any paint or painted part is a Special Order and is usually prepaid.
#210 ·
Oh man! Fantastic!
Crazy that Wikipedia won't allow this for "lack of references." There is so much unsubstantiated bullshit up there as it is...
Thanks for the effort in putting this together...
#211 ·
You will find that our “Lack of References“ is because our information is from us owning the actual Tour Glides, not looking the information up in a book.
#213 ·
I'd say 85/86 judging by the trans cover and clutch cable location. 87 had the rounded trans cover and the cable came underneath on the right (that one is high left).
#215 ·
If my math is right this is th 40th year of the fixed fairing “Roadglide”. Wouldn’t it be awesome if they offered an anniversary model?
#216 ·
Good thought! But they are far more likely to offer that for 2020 model year as of course that will be 40 years on from the ''official'' debut year for the FLT....even though many of you guys recall seeing them in the dealerships and even buying them in late '79.
#217 ·
.....the ''Shovelhead bottom end'' and ''Evo bottom end'' refer to parts within the cases. You cannot tell by looking, Gorillaman.
Sure you can tell EVO and Shovel bottoms are different ... Shovel Bottom with EVO top looks funky as S$%#...
Of course, as we know, clutches were switched from ''dry'' to ''wet'' in mid-year 84 on some models.
Thats when the EVO bottoms showed up ..
#219 · (Edited)
.....Sure you can tell EVO and Shovel bottoms are different ... Shovel Bottom with EVO top looks funky as S$%#...
I may be at cross purposes to you here.
You certainly can tell Evo and Shovel bottoms if you are referring to engine CASES.
But I was describing the situation where - and this has been commonly discussed on Shovelhead forums for 20yrs - INTERNAL new bottom-end parts fitted to late Shovelheads were carried over to the first two years of Evo production.
This is commonly referred to as: ''my 1983/84 Shovel has the Evo bottom end''.
Shovel folks discussing this are *always* referring to the crankpin, sprocket/gear shaft, and the flywheels/rods. The designs of these were updated/changed in the early 80s and were used in the last Shovelheads then carried over into the Evo. In 1986, these parts were updated again and this time got Evo-era numbers.
VISIBLY, you cannot tell that a late Shovelhead has an ''Evo bottom end''.
The first Evo engine cases numbered '''......-83'' did not appear on any production Shovelheads. They appeared on the first Evos sent to dealerships in late 1983.
I've never seen or even heard of a EXTERIOR/VISIBLE ''Shovel bottom with an Evo top'' but I am always prepared to be educated :smile:
I have seen/heard the same discussion turned on its head, i.e. : ''My early Evo has a Shovel bottom end'' i.e. some parts were also used in late Shovelhead motors.
Example: my 1985 Evo FXEF has flywheels/rods numbered xxxx-78G (many annual updates/changes) And the crankpin and output shafts are numbered -80 with letter updates.
It depends on your perspective. But it's all internal.
The 1984-86 limited run of ''four-speed Evos'' (includng my FXEF) all used Evolution engine cases/barrels/heads/rocker boxes. But Shovelhead gearboxes and everything else.
A 1984/85 FLT would, motor-wise and to the eye, be all EVO from the cases up. But the internal bottom-end parts I listed above would have been Shovelhead updates carried over from 1983/84 FLTs.
A very confusing era in Harley history, to be sure.
#221 ·
I tried to make a wikipedia page, but they shot it down due to lack of references. What they don't realize, there [are] no references as the history has not been well documented.
Just joined up, but just saw this. Neat article, and even neater seeing all those who had a lot of these classics chiming in with information. :)
That said: I feel your pain. I keep getting messages from Wikipedia admins complimenting me on being so participatory, so I know about this. I long ago figured out that "if they cheat, I cheat." I do my best to find real-world books, magazines and print-appearances for my references, but if I have to, I'll use something that I've never seen another copy of (besides my own). Did an article on a Japanese cartoon once, and the only reference I had was a book with zero English in it. One such proofreader wanted to take my article down unless I provided him with a copy; I got him overruled quickly (there's always someone higher in the food chain). Another one was about a pulp hero; the only references I had were other pulp magazines, which a couple of proofreaders got very cranky about not having their own copies of. "It's still a valid reference. Get a life." >:) Of such interactions are Wiki articles made. :S
Any book, any magazine, any service manual can be quoted as a source for a reference; no lie. You've seen the one book earlier discussed; does anyone here have copies of magazine articles, newspaper articles or service manuals (even Clymer manuals work) that mention, even lightly, on stuff in the article? (HD publicity offerings would count too.) If there's not a single source that references the Colors Offered This Year, reference each year's article on color offerings; for this, yeah, a source (isn't there an Official Historian at HD? Seems I saw mention of one in one of those NG or DC shows) is needed--but it can be anything that you personally didn't write up. Hey, some of our Classic Riders--didn't they write and self-publish 'Tell All' books about their rides years back? That long ago they didn't have ISBN numbers to track... :)
And yeah, wiki proofers are pretty an@l in general, although I've been lucky to deal (mostly) with people in the real world.
Don't know if this'll help, but I hope it does.
Davey
Reactions: Little Wing
#222 ·
If anybody's interested, I saw this on CL over the weekend. can't vouch for the bike or the seller.
"1984 Harley FLTC. The first year - 4 STAR EVO, (which was the only year they stamped the 4 stars on the case). To some this will be the next big collectable bike, this was harleys come back bike,each bike had it's own quality control person, and that person followed the entire build process. The motors were all balanced and blue printed. Harley wanted to make sure that this was going to be a reliable motorcycle. Many of these bike have over 200k miles on them.It has had the same owner until 2017, 57k mi., Original paint and graphics. New s&s super E carb., new Oil and filter change, new clutch and cable, new battery, runs and rides great. Also have the original carb. and filter housing . $4,800.00 call show contact info
no calls after 10pm. NO TEXT"
https://cincinnati.craigslist.org/mcy/d/1984-harley-davidson-fltc/6702634756.html
#224 ·
"1984 Harley FLTC. The first year - 4 STAR EVO, (which was the only year they stamped the 4 stars on the case). [/url]
From what I remember, Harley puts stars on beginning and end of serial numbers on replacement cases. They had stars on mine when I had the cases replaced on my 1989 Ultra. 1989 was a bad year for BT cases. Harley stopped short of a recall, but issued a Service Bulletin on '89 cases.
#229 · (Edited)
Stars indicated the motor was worked on after it was assigned to a chassis. With evo's the number of stars related to what was done. Bare cases, short blocks, long blocks, or complete motors. Back before evo's, some states still used motor numbers on titles, where as AMF was using chassis numbers. The star was originally to id motors were the motor number did not match the vin. Lots of iron heads were like that as they just replaced bad motors with the next motor up and stamped a star right on the line. And only realigned vins a couple times a month.
As for cases, there was a never ending string of defects. Started out with cold pours in 84. Then the cracks started and there were basically three causes on them. Once the late 91 they pretty much sorted the cracks out, but then the lefty incerts started coming loose. I think it was about 96 or 7 when they finally put all of that to rest.
#225 · (Edited)
I agree with RGR. ''4 stars'' was not a 1984 test-bed thing far as I know, apparently they did that for a short period in that Shovel-to-Evo transition time to stop stolen cases being renumbered And dead right about the 1989 cases. They had some issues through '91 when changing casting production methods. For several years through the early 90s, when affected cases developed cracks by lifter blocks, the MoCo would quietly replace free of charge if owners got upset about it. Many did.
#238 ·
Thank you to everyone who has contributed to this post. I bough an old ugly bike from my uncle about 4 years ago for $500 and finally pulled it out of my dads barn as a winter project. As i started tinkering with it and doing research i began to realize 1. there isn’t a lot of information out there on it 2. it was kinda unique and the looks have started to grow on me.
Reading this post has made me appreciate the bike even more. It’s an almost original 1980 FLT with just under 12000 original miles. i thought all the oil spots and oil caked on the bike was because it maybe hadn’t been taken care of, but after reading all these comments i’m certain that it functioned as normal 😝 . Although it has a chrome air cover and non original carburetor and someone thought it would be a good idea to rhinoline the faring, gas tank and part of the back fender, i feel pretty confident it’s pretty much all from 1980 when it came off the line.
I’ve attached a few pictures. Wish me luck in getting it back on the road!
p.s. missing a left side bag top cover. if anyone knows where i could locate one i’d appreciate it.
Brad
420122
420123
#241 ·
Damn it man, those things are a bear to find since many of them got lost back in the day due to the crappy latches of the time. You can check with PinWall Cycle on eBay...if anyone is going to have one it'll most likely be them.
Are you keeping it stock, or going a retro-mod? I've got a sneaky little black 1981 FLTC that looks stock at first glance, but she ain't, and the changes are kinda hard to spot if ya don't know what you're looking at. In the 1/8th mile She'll smoke an Evo in a heartbeat.
#242 ·
My 89 FLT That is original except for the cone cover & trailer hitch. I've had it since 1991 & it still runs fantastic! I have since retired it as my Road Bike but I still like to ride it. I have considered selling it but don't really know if I want to as it is stated that Harley only made 603 FLT's in 1989
