1 - 17 of 17 Posts
I may be trading my bike in for a 19. I will be removing some parts. I want to remove the iron aces mount. Does anyone know where I can get that metal sticker that we remove above our speedometer?
Sent from my SM-G950U1 using Tapatalk
I’ll look when I get a chance. Honestly I probably won’t be able to get over there before Friday but if I have it still, and I think I do, you can have it.
That would be awesome. Bike won't be traded for a couple weeks. Have to wait on bars. Need to research this sumping issue as well.
Are you sure the mount will work on the new bike? Rushmore bikes have a different Iron Aces part number and the new one is just a stick on.
Reactions: seetiggergo
No it will not work on new bike. I'm going to pull it off to sell.
The Iron Aces Mount for the New Rushmore Harleys is completely different then the 2013 and older Harley’s. As 08Zinc stated, the new version is a stick on. I have one that I used for my Big Baller Gauge Housing and it works extremely well.
I will try and find the part # for the Metal Piece that goes in the gauge housing and post it when I do.
Mike U.
According to my 2012 Harley Parts Catalog the PN is 68492-98. DECAL, speedometer & tachometer cover.
You should be able to pick one up at any Harley Dealer.
Hope this helps.
Mike U.
Hope this helps.
Mike U.
Good lord I typed like every phrase I could think of to find that thing.
Thank you very much Mike u
Reactions: Mike U
You’re very welcome Bro!
Mike U.
Mike U.
but, iron aces sells the stick on base to convert your 2013 earlier road glide mount to the rushmore style.
Hmmmmm
You can purchase these from your local dealership for under $20.
Hope this helps!!
Lindsey :0)
The '13 & older Road Glide Mount is compatible with the new '15 & newer Rushmore Road Glide Mount. You would simply just need to purchase the adjustable base only. Also, if you use promo code "RG-FORUM" members will receive a 5% savings on all Iron Aces Mount purchases.
Hope this helps!!
Lindsey :0)
Hhmph, I traded mine in this weekend. I just took my phone mount off and left the iron aces piece on my bike. This really worked great on my 2013; but, I just wasn't sure where or why I'd mount my phone on the new bike given it's new infotainment sys. If I switch to Aaple we even have have CarPlay now. My current thought is to leave the phone in the glove box.
Discussion Starter #16
Reactions: MightyWhitey
Discussion Starter #17
I kept mine to sell to another road glide owner instead of letting stealership have it
1 - 17 of 17 Posts
