1 - 20 of 20 Posts
not happy with my bars now and saw the holy rollers and think they might be a better fit. currently running Vindikta which are shorter than most and very wide. thinking of the factory 47 but they are very wide as well. these are narrower and look really good but they are only 1 1/4 vs the 1.5.
just looking for some feedback from those of you who have them.
I have the Road 6 Standard Apes on mine. I called them with my questions and they were more than willing to talk candidly about their products. Give them a call with your concerns. Quality wise I have no complaints and the wires pulled relatively easily through the the 1.25 inch tubing. Haven't had 1.5's so can't speak to that. They also have a video specifically on wiring the Holly Rollers on their site. Cool removable end caps to make wiring easier.
https://www.youtube.com/watch?v=fr90KPZ7gHQ
I have 11" Standard Apes. I called and talked to them before ordering. Helpful and pleasant people. I did not want a wide bar, and as I recall these were relatively narrow. I've been happy with them for three years.
I have the 13" Frisco apes on mine,, just switched from the 11". The 11" ride and look like a 12" bar, and were super comfortable. I just like to change stuff up.
Super easy to wire, excellent build quality. Great company to deal with. I highly recommend them.
I'd sell the 11s if you want to try them out for half the price of new.
The Road 6 standard ape (13") was the first bar install I did on a Road Glide (my 2015). They stayed on the bike for almost 3 years before I changed them out. Nothing but good things to say about the Road 6 bars. Installation was a breeze, fit and finish were good. Zero complaints.
Had the 11” standard apes on my 15 RGS. No issues with them, now I am running the 13” standard apes on my RGU. No issues with the wiring and for me very comfortable.
I put a set on my cousins 16. 13" standard. Breeze to wire up. Fit and finish were awesome.
I have the 13" Holey Rollers and really like them. However, the Holey Rollers limit how far you can rotate the grips and hand controls if you bring the bars back closer to you. I have my bars rolled back to be inline with the front forks and the controls are pointed slightly down. Not an issue, but any more would be.
Contemplating these as well as FMB bars, good point , I usually line up my bars with the forks, sometimes a bit more back depending on the bar, I really like the look of the road 6 bars.
Does anyone with a pre- Rushmore glide have issues rotating the controls like 08 zinc does? I know the newer glides the controls are slightly different.
I just watched this entire youtube video and it was very well done
Looks like if you take your time this job can be done in your garage without any issues
Follow this video, step by step and you should be good to go
Great looking bars IMO
Swomack
Saw that awesome video, wiring is easy just wondering how much can you rotate the controls , on 2013 and earlier seems like they don't interfere with the gussets, I think I am decided on 13 inch holey rollers , like the look.
On 15+ the rotation is limited by the nubs on the controls(easy to remove) Then there is only limitation from the wiring slack, and clutch/brake cable slack.
1 - 20 of 20 Posts
