1 - 3 of 3 Posts
(TRANSLATION Google)
I will try to describe my problem!
I live in Russia! I have a Harley Fat Bob FXDF 2010 (K & N, ThunderHeader 2in1)
I chose the module to model my motorcycle and bought it. For my Harley suitable module № 309-485, with delivery to Russia I paid $ 1600!!! BUT WHEN I CAME TO MODULE FOUND THAT IN THE BOX 309-485 WRITTEN, AND ON THE UNIT № 309-460 (Model No 309-460)!!!! I contacted support and they told me that they are compatible, but all the same it's not nice!
Now the main problem! I installed the module, loaded the desired card and everything was very good work! The bike was just great! BUT! I drove about 600 miles, and then one morning motorcycle bad wound, Chek Engine caught fire and died when I was to go, there was a detonation at a set rate, difficult to start the engine! I looked up the error codes on the speedometer motorcycle, it was P0132 and P0152 which means bad oxy sensor! When I got home, I cleaned the unit and loaded the map, then made all the settings, everything worked well again, I drove Ridding Session: 1) drove 25 miles on the 0.5 throttle, the engine stopped, then started, it's okay 2) started gone another 25 miles, 0.7 throttle, the engine stopped, began to start the engine, the engine wound up badly! Then again caught fire exact same error P0132 and P0152!!! I'm not lazy and again shook the map passed, but just as bad!
I DO NOT KNOW WHAT TO DO! I make the collection of data and send to Support! But I understand, after all the downloads or installations, MOTORCYCLE WORKS WELL BUT AFTER A LITTLE TIME (START AFTER 3) it throws an error and appear DETONATION!
ME NOW difficult to get back to America, I DO NOT EVEN KNOW HOW TO DO IT! MAY BE DAMAGED OR MODULE SENSORS! MAY IS NOW A NEW PIERCING MODULE 309-460??
Batteries and all the wiring I HAVE IN ORDER!
I installed SERIAL MODULE AND KEEP DRIVING!
BUT I WANT TO BIKE TO WORK PROPERLY!
If anyone encountered this problem HELP ME!
I am very upset, it's more money for me!
I think you have the wrong unit. The 309-485 should be the correct one for your bike. I would return it for the correct unit. Might be easier said than done considering you are in Russia though. Good luck, I hope you figure it out.
If you can figure out how to put Edward Snowden in a box and send back to the USA I'm sure the US Government would gladly send you the correct one. :)
yes, I think grained return it. but first bike was working great! and support said that the modules are compatible! I was not pleased that I was so deceived! the difference in price between the modules is $ 20, is it so you had to do because of some $ 20! shame comrades!
1 - 3 of 3 Posts
