1 - 10 of 10 Posts
Hey all you thundermax users I have a friend that recently purchased a 2009 ultra classic cvo just before pulling out out the dealership the mechanic came out and told him to never use the kill switch because if he did the thundermax would loose its program and bike would not run is there any truth to this thanks for all help in advance
The Greatest Moderator on The Internet
That's news to me.
I use the kill switch all the time and never had a problem.
As a matter of fact, I don't recall reading that in the instructions when I installed my Thundermax.
Mike U.
Had the Thundermax on my classic, used the kill switch all of the time. Never had an issue.
Hawkman
No, it will not lose its programming. But if power is lost to the T-Max (battery disconnected, ECM fuse pulled, main fuse pulled), it will not recognize the sensor settings on the bike. The program will be intact. So if you lose power to the T-Max, you should cycle the power 30 seconds on, then 30 off, and repeat for 3 full cycles. This allows the T-Max to reacquaint itself with all the sensors on the bike again. The install instructions come with a sticker to be placed next to the battery with this info on it. This must be what the mechanic was thinking of.
I've been using the kill switch for years and was told the same thing by Chris Waddell of Cycle Solutions Racing while in Sturgis. Chris equated using the kill switch to pulling the plug on your computer to shut it down. Although I have a TMax, he said it's proper to shut down with the ignition switch regardless of the ECM. Not sure what to believe, but have been using the ignition switch lately anyway.
Discussion Starter · #9 ·
hey all thanks for your input and experience. I have been told by Tallahassee HD and Panama City HD to always use the kill switch first then ignition switch because the kill switch shuts off the fuel pump (the ignition switch also cuts off fuel pump). Sooo confused!!!! I will tell friend what you all say let him make up his own mind.
thanks
I had a T-Max on my last bike. It is actually still out in the shop. I hear others say how great they are. Personal experience says different. Using the switch will not kill the programing. The maps while many are limited. So any mods will require trial and error tinkering with the maps.Tech support is hit and miss also.
1 - 10 of 10 Posts
