You may have to click on basic settings and reset the compression release delay. There was never a feature the had the bike turn over certain amount of rpms before there was fuel and spark.
The compression release delay setting is for the Automatic Compression Releases (ACR). When turning on the ignition the ACR's will open and then close after so many rpms, the setting is usually 2 rpm's.
The initial fuel pulse and the cranking fuel adjustments would be what needs adjustment.
Also check other adjustments such as speedo calibration.
