1 - 18 of 18 Posts
Ok guys, 2022 road glide st, the clutch cable runs inside triple trees all crazy and its on the right side of the bike , im in a cramped and hot work space with no lift, any tips on re routing the cable, as in should i just make some slack in the adjustment and disconnect it at the lever then pull it through to re route?
The cables run through a plastic holder on the right side right next to the neck. If you haven't already, Pop the cable out of there and you should be able to pull it a little and get some extra slack. Then put it back in. There may also be some zip ties holding it place below the clamp.
I had issues putting on 14" Factory 47 bars. I initially rerouted the cable as best i could, but it kept pushing up against the speedo cluster from underneath. I went with the fat baggers 6"clutch extension which is more than i needed. Someone on this forum is actually selling theirs for $90.
1 - 18 of 18 Posts
