1 - 9 of 9 Posts
All K&N's (Harley brand or otherwise) require oil to work properly. Some of the newer Harley Screaming Eagle filters are dry filters (not K&N) - no oil required - easy cleaning.
some filters like k&n need oil to catch the very small particles or it just goes right in the intake and thru motor, which can cause damage
I was surprised my filter is a dry filter (marked on filter - no oil). I had stage 1 done before I picked bike up (was new, showroom floor to service dept) and was told it would be K&N. Thought all K&N's were oiled. There's a very good writeup/comparison of filters on this site, K&N doesn't rate well for engine protection. That said I am planning on changing out football anyway, when I do I will do much better research before picking next air intake. Some day, 2 in college right now, no extra funds available.
Our Ful-Flo filters,(3.5" thick, and the largest to fit under a football cover) manufactured by Green Filter, Brodock, PA, are designed to run completely dry.
Scott
Banned
check with the mnufacture.if its ment to be oiled,oil it or like said earlier,it wont catch smaller particles.if ment to be dry,you ruin the element if oiled
1 - 9 of 9 Posts
