1 - 9 of 9 Posts
Has anyone mounted a tombstone tail light to their Shark?
Oldbie, if You're mechanically and electrically inclined I am sure that it can be done.
I believe it would require drilling holes in Your fender and having a bracket behind the fender to mount it to.
You would also have to tap into Your brake light wiring to get it to work properly.
Best of Luck.
Mike U.
^ I'm guessing that is an older one with a centre taillight already and swapped out the square one with the tombstone.
The one i installed on my friends low rider had to have a ground added to it before the blinkers would work right. No ground in the wiring harness or the one i put on there was defective.
Here's a couple pics I found of a bagger with the tombstone light. Not bad, but looks better on the Deluxe imo
That looks nice. My RGU has the oval-ish light now, I am wondering about fender curvature and tombstone lamp curvature being compatible. I don’t mind drilling some holes but I don’t want to do body work and paint.
1 - 9 of 9 Posts
