Does anyone run a v n h pro pipe 2-1 chrome with the boom audio speakers and no amp. I am curious if I will have trouble hearing the HK set up.
Ultra but at times will detach t pak and lose rear speakers
I ran the Vance and Hinze 2 into 1 pro pipe. Nice but you might not be able to really enjoy a stock radio without an amp. I run a Hawg wired speakers and Amp, That is a good set up and caused no problems.
I had the pro pipe on my '10 with the boom speakers... wasnt the best, but wasnt too bad either... id suggest atleast swapping over to 6.5's as you will get better sound out of them. I just started swapping out my audio today in my '13 and even just swapping up to a higher grade speaker off the radio is a night and day difference.
Thanks for the input on the boom speakers, I am joining the stereo game for the first time with my 13 rgu. I put 75k on a r king with no tunes abd this tunage thing is new. I dont have it yet so the unknown factor is killing me as to what I can or cannot hear. I might look further into the amp as you said
pro pipes are normal sounding
an amp is in order for sure
there are several model amps $100 to $400 range, and speakers, all sorts
if you PM me I'll tell you my favorites of the moment if you state a budget, it helps.
to me $1/watt seemed reasonable, for everything
reality was, closer to $3/4 watt, and that was reasonable
but you can get started for as little as $200-300
