Hi
Could someone tell me Where to buy some US tools for my Harley. In Denmark most tools are in mm and I am having a hard time finding prober tools
Need a setup so that i can fix stuff like fairing and small things.
So I anyone gas got a link to ebay or amazon ...
Thx
before you go ordering a complete see tool kit, go out to your garage, and start putting your wrenches on the things that you would be working on. there are very few things in routine maintenance that you couldn't do with a metric wrench set. 1/2'' = 13mm, etc. you might find that you'll actually need very few tools, and those could be ordered off amazon, etc.
brake caliper bolts are 10mm. battery terminals are 10mm.
As Skratch said check all your bolts first; you will most probably find a mixture of SAE and Metric on your beastie depending on its year.
I use my ratcheting wrenches all the time. You do not need many bigger wrenches, unless you are pulling the axles out and messing with the front suspension. Those wrenches (or sockets), you can buy individually.
