1 - 18 of 18 Posts
The motorcycle was a stock 2012 103"
Prototype cam specs .510 lift 235/[email protected] 107 lsa
V/H Power dual Headpipe & V&H 3" Round slipon exhaust
SE ventilator air cleaner
Quote from Torqueinc >>
"Cam is one of my grinds
Cam Specs .510 lift 235/[email protected] 107 lsa
Designed as a bolt in with pipes and AC for the 103/Bagger/trike for those that want a touch more but do not want to change even pushrods. Wanted a broad flat torque curve and a quiet cam.
I have at least 6 other grinds 2 are done and another being ground around a package that I am putting together."
Nice lines.
Stephen
I'm liking those tq numbers!
Discussion Starter #15
John was sharing this cam info and I thought I would share the results. If you want to order this 103 cam, you can call John ( Torque Inc ) 419-651-1802
He also told me he would have a website up and running with his cams sometime this summer
Tom
I'm very happy with the HD 255
Discussion Starter #17 (Edited)
My experience with the 255 cams was lousy. Cost me a starter to figure out that they were lousy cams in hot weather with hot starting without compression releases and would ping at times with poor quality gas
1 - 18 of 18 Posts
